Simple Sketch, Fusion360 crash!
macmanpb
Message 1 of 8
macmanpb
Hi, i have made a simple screencast to show you the steps to reproduce the crash.
The diameter dimension of the first circle is important!
Replies (7)
Message 2 of 8
LMD001
Hello macmanpb,
Same here, I can reproduce the crash, did not send the CER.
I created the first circle and the second circle of a lesser diameter, then connected the tangent lines, then dimensionned the second circle, no crash.
Best regards,
Ludo
Message 3 of 8
jiang_peng
I tried on Windows 10 but can not reproduce the crash. Could you please send the CER?
Thanks for the help!
Message 4 of 8
macmanpb
Three times sended 😉
Message 5 of 8
macmanpb
I am using a MAC...
Are you sure you have placed the dimention on the first circle?
Message 6 of 8
macmanpb
Hi Ludo,
yes i found this workarround too. But i want pointing this error. 😉
Thanks Ludo...
Message 7 of 8
jiang_peng
I just checked the CER report - in fact it's a known issue. We have already had the fix and it will be included in the future update soon.
It crashes inside sketch constrained status checking. So another workaround is just turning off the sketch constrained status checking. I didn't turn it on so I couldn't reproduce the crash.
Message 8 of 8
LMD001
Hi macmanpb,
Hey, no problem and you are very welcome!
And as it seems, already solved in a future update.
Best regards,
Ludo
