What doesn't match? Displacement or stress?
Your displacement value at the point of load application should be within 1% or less. Stresses will be different depending on mesh size, element type, material properties, stress criteria and constraints. Also, on a wide beam like the one you have, Poisson's ratio is going to affect your results too (try setting it to zero).
The only thing you should be concerned about is the deflection, if you can get that right or get confidence in the value, the stresses will be correct.
If F360 had beam elements, you'd get exactly the same results as the ones out of beam tables. But a solid mesh will give slightly or massively different results, depending on where/how you inspect results in the mesh.
Do a benchmark analysis with a simply supported beam of very simple geometry, e.g., a solid rectangular beam without fillets, holes, etc, and make it quite long so that it looks like a beam). Then compare this with the result form a hand calculation for the same beam. Once you get confidence in the result, apply the same approach to your more complicated model.
whunter
