I'm trying to take the advice of prior posts and take the time to constrain ALL my sketches. Maybe it's because I'm not that skilled in F360, but I'm struggling a lot to figure why something isn't constrained and how to constrain it.
A screenshot of my latest struggle is below along with an exported model.
The radial line segments that connect the arcs are constrained to be co-linear with the origin.
The radius of the outer arc is dimensioned. The difference between the inner and outer arcs is dimensioned.
The inner holes geometry won't move and everything behaves as I expect when change dimensions. The holes extrude Ok.
I was advised (I think) to avoid using circular pattern in a sketch and use Create Pattern from the Solid Design workspace. But, I couldn't figure out how to select the holes for a pattern repeat.
What am I missing? It's taking WAY to long to figure out to constrain my sketches.
