Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Shetch: Unable to trim 2 rectangles
10 REPLIES 10
Message 1 of 11
1514 Views, 10 Replies
I'm trying to combine to rectangles in sketch mode. I put the smaller one flush against the larger one, trimmed the outsides of the smaller rectangle at an angle. However, when I attempt to trim the inner line to connect them, the red line indicates that only the line used by the larger rectangle can be trimmed whereas I want to trim only the smaller rectangle line. I see two white points so I would think it would offer me the chance to trim the smaller rectangle line. Why can't I?
10 REPLIES 10
Message 2 of 11
jiang_peng
It is possible that the two white points are not actually touching the longer line. Could you please move the two white points a bit and try again?
thanks
Message 3 of 11
in reply to: jiang_peng
I zoomed in all the way and it exactly touches but if I move the point a tiny amount and bring it back for both points trim does work. Is that a bug?
Message 4 of 11
jiang_peng
In some cases, the gap between geometries is too small. Even zoom into maximum, we still can not see the gap with our raw eyes
Message 5 of 11
jeff_strater
you can tell that the points are not really connected because they are drawn as open circles:
If they are connected, you should see a coincident constraint.  Here is an example of a similar sketch where one side is connected and the other is not.
So, the best way to get this to work is to add coincident constraints between the point and the line.
Jeff
Jeff Strater
Engineering Director
Message 6 of 11
in reply to: jeff_strater
OK, so I added coincident constraints by clicking the coincident constraint button, clicking the white point followed by clicking the line. I did that for both points. As the attached image shows, the 2 coincident contsraint icons show up. When I go to trim it still doesn't work. What am I doing wrong?
Message 7 of 11
jeff_strater
Very strange.  This should work.  Here is a video showing that it works for me:
However, your picture is evidence that it does not work for you.  Would you be willing to share your design here?  I think that's the only way we are going to get to the bottom of this.
Jeff
Jeff Strater
Message 8 of 11
Message 9 of 11
Or this?
Message 10 of 11
Attaching screencast:
Message 11 of 11
jeff_strater
Thanks for the model, @Anonymous,
I would say that this is a bug.  This should work.  I suspect the problem is that there is some overlapping geometry:
and this is confusing the Trim command.
If I delete that line, it helps, but it seems that Trim is still confused.  I have to actually drag the small lines to get it to work.  Here is a video:
I'll file this as a bug.
Jeff
Jeff Strater
