Sheetmetal Joggle Bends
Hi everyone!
I'm trying to create a joggle bend on the edge of a sheetmetal part for the purpose of attaching it to the edge of another sheetmetal part with the edges flush. I have a horrible workflow of guesswork and sketches with direct dimensions (i.e. not in terms of sheet thickness) and I'm wondering if anyone has a good way of doing it? (Image below for reference)
My current workflow is to cut the flat face with a sketch specifying the width of the flange and the depth from the edge it should start (manually calculated). Then I do a flange at 45deg inward, for a distance of sqrt(2) times sheet thickness, and then another flange at 45deg to that to create the recessed tab as you see it there.
I believe other packages have a workflow to do this (at least semi-) automatically?
Appreciate any help or discussion - thanks!
