Sheetmetal Assembly - Flat Patterns
KrownCNC
KrownCNC
I'm designing an assembly of sheet metal parts and I think I'm stuck.  I'm individually going through each piece and generating flat patterns but in some cases, like the stabilizer bracket, I can't get flat patterns to generate for more than one piece at a time.
Did I screw myself up, or better, where did I make my design mistake?
Thanks in advance
MODEL LINK: https://a360.co/4eoPL2Y
jhackney1972
You have probably run into the rule that you can only have one flat pattern for one body at a time.  Even if the bodies are under a component, this rule applies.  What you want is to always create sheet metal components, even if they are sub-assemblies of a top level assembly, then you can create a flat pattern for each and achieve what you desire.
All is not lost, take a look at this Blog Article and Video for a method to create sheet metal components from sheet metal bodies since I am sure you have noticed, Fusion does not allow this directly.
John Hackney, Retired
KrownCNC
Interesting, and inconvenient.  Let me give this a shot...
KrownCNC
It appears to work.  Thank you.
Strange workflow...
