Sheet Metal
Sheet Metal
mariusche
Message 1 of 33
Sheet Metal
mariusche
Hello
Replies (32)
Message 21 of 33
TheCADWhisperer
@mariusche wrote:
I need like this
@mariusche
Before I spend time on this - are you still looking for solution?
Message 22 of 33
mariusche
hello,
yes
Message 23 of 33
TheCADWhisperer
I have not figured out how to do Round corners in Fusion like you can do in Inventor, but the rest of this should give you some ideas.
I like to make Flat Pattern early on in the design process and keep toggling back and forth to make sure all is manufacturable.
Message 24 of 33
daniel_lyall
@TheCADWhisperer A question why did you use a sketch and a extrude to extended the width of some of the flanges like what's pointed to with the arrows, when you can use the command inside sheetmetal to do it like what is in the pick.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 25 of 33
TheCADWhisperer
Uhmm, well - basically because I am clueless in Fusion.  Smiley Tongue
I think I already figured out a much more efficient way to model the part, but I would really like to figure out how to get those circular bend corners in Fusion.
Message 26 of 33
daniel_lyall
It's under the override rules in the flange dialog if you only wont to change what happens with that flange.
Or if you wont it to happen to all flange you edit the rules by clicking on the sheet metal rule symbol in the ribbon then click on the pencil that the arrow is pointing to what brings up the edit rule dialog
@TheCADWhisperer I have done this for others who don't know sheetmetal at all.
Daniel Lyall
The Big Boss
Mach3 User
Message 27 of 33
JDMather
Can you edit the file and show example - I fooled around in there for a bit and couldn't figure it out.
Message 28 of 33
daniel_lyall
@JDMather Yep will do.
@TheCADWhisperer here's me showing changing the width of the flange, what I did at 1 min 30 is how to do tabs promm showed to do it this way.
Then at the end I show a way to have 2 flanges on the same edge.
Daniel Lyall
The Big Boss
Mach3 User
Message 29 of 33
mariusche
thank everyone for your effort
I learned a lot from a simple thing
Message 30 of 33
daniel_lyall
@mariusche there's more to come
Daniel Lyall
The Big Boss
Mach3 User
Message 31 of 33
mariusche
but... if you have pleasure and time for"much more efficient way" I am very interested
anyway thanks for your time
Message 32 of 33
mariusche
I've seen a lot of interesting things
Message 33 of 33
daniel_lyall
@mariusche Yep I have a few bugs to sort first, to get a clean work flow that does not kill sheetmetal, I have worked out a few way to do what you need most kill Fusion in it's tracks, Its all fun for me.
Daniel Lyall
The Big Boss
Mach3 User
