Sheet Metal - Joing bends from different components
an18211821
Message 1 of 1
an18211821
I have a metal sheet body and a metal sheet component. on the edhes of them i need uniform 45deg bends.
For example for bends between the same component i get the result that i need
But here , would like the same result on the connection between the body and component
But because i can not select at the same time the edges when i make the bends i get thi following unwanted result
Replies (0)
