Sheet metal flat pattern not using selected face
Two of the components in my sheet metal file are just circular disks.  When I try to use flat pattern on either of them it shows the edge view.  I thought maybe it was just showing the wrong view, so I exported the flat pattern as a dxf and opened it in another file.  The dxf is the rectangular edge view of the disk.  I know the dxf is just a circle and I can make another sketch to get a dxf from it, but it appears to be a bug to me.
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file here?
Of course I could take the time to generate my own file to verify the behavior and suggest possible solutions, but since you already have it done....
Hi, I have had the same issue on several sheet metal pieces, it seems to happen randomly, but mostly on disc-type objects. My f3d file is attached, both sheet metal pieces have this problem when I flat pattern them.
patilsm
Hi @logicstreetscene@schmittre,
Thanks for your post and connivance you facing while doing flat pattern.
Yes, Also observe this issue with newly created same type of object. So for analysis purpose, I have reported (FUS-39489)
and will ask dev to analyse.
If you found some more parts then please attached, so we will look into it.
Sagar
Sagar Patil
Software Engineer
Quality Assurance
Autodesk, Inc.
Hi, I ended up doing a separate post in Support with more info:  https://forums.autodesk.com/t5/fusion-360-support/try-to-flat-pattern-a-flat-object-with-curved-edge...
It seems the problem occurred because there was no straight lines. The issue was solved by making a 0.1mm line section of one of the curves in the sketch. I then selected the face I wanted to see in flat pattern, and it worked.
harriyt72
Or, you can rotate the _body_ of your sheet metal component so it faces front of component.
No need to mess with the body shape.
