Sheet metal flat pattern export dxf as part name
alexhardie
alexhardie
When I go to export a .dxf from a flat pattern, it would be really helpful if it would default the export name as the existing part name.  Right now, I can't even see the part name from within flat pattern, so when exporting a lot of .dxf's from a larger assembly, it's really tedious because I need to memorize the part name before entering flat pattern.
What would be even cooler is if I could click one button to export every sheet metal part as a flat patterned dxf!  I can dream big right?
CMCORE
I've been dealing with this for as long as I've been using Fusion. Definitely would be nice to not have to manually type in part name/number for the hundreds of parts I deal with when exporting. I'm literally opening the configuration pane to copy the part name before going to export DXF, then pasting. Very clunky.
Or could pay the $1400/year for the Manufacturing extension to have the ability to auto-export, auto-nest all the sheet metal.
