sheet metal features needed
Like the title suggests, here are 5 sheet metal features needed.
1) Normal to thickness cut. I know the work around is to cut,then flatten, and trim some more. It is easier if it could be handled in one step.
2) Closed corner. Unless I am missing where this command is located we need to be able to close corners (2 and 3) with conditions of closed, open, overlap, gap, etc.
3) Hem
4) When you create a flange, have the ability to edit the sketch of it.
5) Contour flange, you can start a sheet metal feature by drawing a profile, lets extend this by having the ability to draw a profile on the edges and when selecting the flange command it turns this profile into a flange that is attached to the existing sheetmetal body.
Bryan Lagrange
