It was a bit of a struggle to find much documentation on the various modes of text in the Title Blocks. So through lots of trial and error I wrote down these notes, hope it helps someone! Link to template below.
Title Block Editing Notes
1. Create template
1.1. Set fonts in settings and sheet settings before creating Attribute text
1.2. Create TitleBlock and populate
1.2.1. TB 'Text' edits will always be visible and persistent across pages
1.2.2. TB 'Custom Attributes' fill these with suggested text, displayed with populating a TB (Attributes can be pre filled, see Page Title)
1.2.2.1. TB Attribute population edits are not persistent across pages
1.2.3. TB Attributes are inherited from design file, can't really config these
1.3. Create any template sheet edits
1.3.1. Sheet edits create page defaults, but are not persistent
1.3.2. Populating TB Custom Attributes will be copied, but not persistent
2. Create Drawing
2.1. Template views will not be applied if creating a drawing from animation
2.2. Fill TitleBlock - double click - populate level
2.2.1. You can see and populate Attributes (blue), changes not persistent on other pages
2.3. Edit TitleBlock - edit level
2.3.1. Edit the black text as needed, all changes will update across pages.
