Hello! @brianwildes8
If you are facing some kind of problem to make the file sharing link available within Fusion 360 you can use the A360.
As follows: Go to the file inside the A360 and follow the steps shown in the pictures below!
So you can make the link available to other users, this can be a way to solve your problem!
I believe these steps can help you in your work, good luck!
Did you find this answer helpful? If so, please use the Accept as Solution or Kudos button below.
Link A360: https://a360.autodesk.com/
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
