Setting Position of Hole
fsonnichsen
fsonnichsen
I always have problems setting relative geometries on components. In the case shown here I simply want to space 2 holes. They must be centered along the long axis of the device, and a specified distance apart. I have accomplished this by subtracting in my head and spacing them 0.2in from the edges of the body. However I would prefer to reference them from the center of the body.
  There is no way to "Construct: Place Point on Center"--something that continually annoys me (and I think others).
  There is a "phantom" centerpoint that mysteriously appears as you move the hole about.  I can place the hole on this point--but there is no "select " for this point in the Reference boxes so I can move the hole from the center.
  I tried putting in 2 construct planes as shown, hoping to use them to set the "select" distance. But these disappear when I try to place a hole.
I have reviewed the written documentation regarding construction, assemblies etc but I don't see basics like this well written.
Any suggestions appreciated
Fritz
HughesTooling
Personally I always use a sketch.
Mark
Mark Hughes
Owner, Hughes Tooling
jeff_strater
I would do this using a sketch.  You can create a centerline on that face by snapping to the center of the short edge, then place two points on that line.  That centers them side-to-side.  Then just add dimensions to the ends, and make them equal.  The use the "from sketch" option in Hole, so you can create both holes at once:
Jeff Strater
Engineering Director
HughesTooling
Also for something symmetrical like this I'd tend to make it symmetrical around the origin. Makes it easier to get references.
Mark
Mark Hughes
fsonnichsen
OK and thanks for the suggestions. I had originally created (no sketches) a hole and clicked it onto the center of the base object which always seems to work. I think this is what Mark mentions in his 2nd post.
   The problem was that I could not get the "select" in "hole" to come up afterwards to set the spacing. I tried again and it worked this time. Maybe a glitch.
  I see that Jeff's more extensive method does allow more definite specification of dimensions which would be useful. I guess there is no problem with having additional sketch in my time line.
  Thinking back on my original attempt--I still don't understand however, why my construction planes vanish when I try to place a hole--seems like there are times when this would be needed. Also it would be nice if a point could be centered upon a symmetric object (other than a circle, sphere, torus). I can see a lot of uses for this.
Thanks all
Fritz
Ajay_Kumar_Reddy
Hey @fsonnichsen,
Adding to @HughesTooling and @jeff_strater
You did great in using reference 1 but there you forgot to use reference 2.
1. click on reference 2 in the dialogue box
2. select the horizontal line(2" line) on the top face.
3. I found that the top face vertical distance is 0.188" you need to enter 0.188/2 in the dialogue box as shown.
there is no need to do additional things such as construction plans and sketches.
I'm attaching the f3d too.
fsonnichsen
Yes-the "Selects" usually work. I had some problems initially with them and not sure why. I had a few other recent issues and 2 crashes--maybe time for a reinstall
thanks
fritz
