Set the distance between lines
wcarlsonM2NUS
Message 1 of 10
wcarlsonM2NUS
Greetings.
I'm a newbie here with zero CAD experience. I've made a couple of simple nick nacks, but now I'm trying to design a radio bezel. So I've created a sketch, extruded it to the appropriate thickness, created a sketch on that and cut a rectangular hole through the original sketch by doing a negative extrusion.
Now I need to adjust the hole position and size by setting the distances between the vertical and horizontal lines of the hole and the corresponding external vertical and horizontal lines of the original sketch.
If someone can point me in the right direction it would be great!
Thanks!
Replies (9)
Message 2 of 10
g-andresen
Please share the file for investigation.
File > export > save as f3d on local drive  > attach it to the next post
günther
Message 3 of 10
wcarlsonM2NUS
Thanks for the response. I have attached the file as requested.
Message 4 of 10
rushabhthakkar_910
@wcarlsonM2NUS, Attached a video. Hope it gives you an idea on how to dimension it..!!
(Edit-Attaching model too for your reference)
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 5 of 10
wcarlsonM2NUS
I do appreciate your response. I will need to fix holes for mounting, so this is very helpful but my original question pertains to the rectangular opening for the radio itself.
Message 6 of 10
g-andresen
follow the srenncast: project contour > create elements > dimension
günther
Message 7 of 10
wcarlsonM2NUS
Excellent, now how do I relate the four sides of the rectangular opening to the four external sides of the body?
Message 8 of 10
wcarlsonM2NUS
OK, I used the dimension feature of the sketch palate to dimension the opening. Thank you for the help!
Message 9 of 10
wcarlsonM2NUS
Thanks, the dimension feature was the trick.
Message 10 of 10
davebYYPCU
One Dimension for each.
Lots of ways to get the same thing in CAD, aligned midpoints, etc.
Might help....
