Selection tool
Selection tool
Selection tool
So, I'm attempting to fillet a complex body and am unable to select all the edges at once- the hidden edges wont select. I've tired changing the selection filter to edges only. I've tried switching through all of the visual styles. No luck
I would prefer if the program did not select hidden edges in a solid body visual style, but whenever a visual style displays hidden lines I would like to be able to select them regardless of which direction I view the object.
schneik-adsk
In the select menu, There is a select visible option, turn that off.
Kevin Schneider
