Selection set don't work with sketch profile
jonathan_lafontaine
jonathan_lafontaine
Hello group,
I have many components with many rivet holes. I wanted to group those holes in my sketch so that when I import a component into my design, I can extrude/cut all my rivet holes all once in my wood sheet.
It would appaers not working with faces while other people on the forum say's it should 🤔 I can select circle, line and point but not faces.
I know more messy option by extrude all my rivet into bodys but the problem is I cannot combined them together because they are seperate body, I would then need to create a selection set of those body or I can combine them into a component is an option but also messy.
But there is an "create group" option when I select faces, what does it do? I coulndnt find any information for those type of group. It doesnt show in the timeline or the browser.
I post a video on Youtube to explain. Thank you for your time
https://youtu.be/SOFbRdI-A28
jeff_strater
Your terminology is wrong, but your conclusion is valid.  Your video shows selecting sketch profiles not faces.  And, yes, selection sets do not work with sketch profiles.  I don't know why.
Jeff Strater
Engineering Director
jonathan_lafontaine
Hi! yes, you are right, English Is my second language. I edit the title to reflect properly my issue.
