Selection mode
Selection mode
etfrench
Mentor Mentor
Selection mode
etfrench
How did the selection mode in a sketch change from a rectangle to free form?  How can it be changed back?  There are no obvious menu items to control this.
https://knowledge.autodesk.com/community/screencast/f72568d8-3986-4fcc-8349-2b2ce364cb3d
ETFrench
jeff_strater
Somehow, you must have selected Freeform selection mode.  All you need to do is choose Window Select from the dropdown under Select:
And it'll go back to window select
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
NicolasXu
Hi etfrench,
The selection method can be changed back from the Ribbon. Please refer to the screenshot below. We can also change it via shortcut key - "1" for rectangle selection and "2" for freeform selection.
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
etfrench
Thanks.  It was probably the shortcut key that did it.
ETFrench
etfrench
At the 2:25 mark in this screencast the Select tool changes from Window Selection to Paint Selection.  The Dimension tool was active at the time.
ETFrench
