selection box it sketch fillet
is it possible to fillet a sketch using box selection/ freeform selection instead of clicking the point one by one?
sanket223.patil
 No ,
But you can directly click the corners for a Fillet , If there are no construction diognals .
Sanket Patil
Mechanical Engineering
Expert Elite
TheCADWhisperer
Can you go ahead and do it the hard way and then File>Export and Attach your *.f3d file here?
Perhaps a Feature Fillet would be a better solution than a Sketch Fillet.
sanket223.patil
(Yes , and also easy to Edit directly from Timeline , rather than to open the sketch and edit )
Sanket Patil
Expert Elite
Relax, Im just asking about selection box in sketch fillet and to your answer is that fusion360 cannot do that. That is all I need, an answer.
As a Newbie in F360, Im asking in this forum because in other program it can do that very easily, Im afraid I might do it the wrong way.
As for why using the sketch fillet instead of fillet feature? there is cases where you just want to make a sketch without making it 3d (example: logo, lasercut plotting)
Thank you for the answer.
