Selecting Profiles
Selecting Profiles
Claytonics
Selecting Profiles
Claytonics
This is killing me,
How to I have fusion select only sketch profiles, excluding surface or face profiles? Only the sketch is visible, I have I'd have to select every internal face profiles to get the extrude I want. I'm clearly missing a setting somewhere.
Thanks for the help in advance.
laughingcreek
start be deselecting this setting in preferences-
then redo your sketch.
Claytonics
Yep, Thanks!
Major PITA
jhackney1972
I hope I am understanding, try holding the Ctrl (Cmd) and used the left mouse button to select or de-select desired profiles.
John Hackney, Retired
jeff_strater
"How to I have fusion select only sketch profiles, excluding surface or face profiles?"
You can control the selection filter, either during a command (e.g. Extrude), or when no command is active, using the Selection Filter dropdown.  Set it to only Sketch Profiles to limit the selection to those types.
Jeff Strater
Engineering Director
g-andresen
Show what you want at the end and share the file (f3d)
günther
