About 3 weeks ago you helped me out with a drawing problem that was very easily fixed by you. Now three weeks later I am still working on a different problem. I am trying to mill the football.
SHORT STORY: Just tell me how to mill this **** thing. I know I am making most of the correct selections.
LONG STORY VERSION 3:
No matter what operator I try to use under CAM I keep getting errors. It is not a pocket, 2d contour, slot, trace or anything else. I have tried 2d and 3d and just can not get it to do anything right. To refresh your memour I have a football with three different levals of the star on it. I figured out a lot of things not to do but can not figure out what the heck I need to do. I tried to use the stock contours and that allows me to pick the area I want to mill but then later tells me that I do not have a pocket picked. Sometimes it tells me that I do not have the correct depth set. So many different errors I can not list them all. I have attached several pictures. I want to leave the inner most star alone. "Stock heigth". Then next star out I want to drop down 1/10th of an inch. I have tried to use both positive and negative numbers but neither one work.Then the 3rd star out I want to drop another 1/10th of an inch. I know it has to be a negitive number because it is below where I have the triad of arrows (X,Y,Z) which is located at the stock (work piece) top, left and closest to the operator in the Y. Again it just can not be this darn hard. I have watched 100s of not 1000s of videos by now and do not even know what to call this.
I am choosing 1/8" flat bottom bit.The area I am trying to cut is just over 1/8" wide. No fluid, Try to select the geometry but have some trouble getting that right some times. I was getting all kinds of different things selected from one line to the whole screen. tried both positive and negative for bottom of cut. 1/10th deep. several passes. Once again it just can not be this darn hard. You made it so simple to correct my drawing of the item. I really do thank you for your help.
LAST OPTION: Just shoot me now!!!!
