Select ALL verticies - t-splines Pull command
changedsoul
changedsoul
I am having trouble with the "Pull" command when in sculpting.
Trying to create a handle bar mount for my bike.
I drew my stem, then created a cylinder t-spline for form around the stem - identical to this tutorial( https://www.youtube.com/watch?v=x_T5AlilTDc )
So I am following along and trying to duplicate and learn. When I get to the part where you get the cylinder to snap down onto the stem, I am unable to drag a box around the entire object to select all the points. The Box draws fine, it just never selects all point.
Is this a bug in this current version? It seemed to work fine in the video.
jeff_strater
do you have "Select Through" enabled in the selection filter?:
this allows you to select vertices that are obscured by other geometry
Jeff
Jeff Strater
Engineering Director
changedsoul
That was it! Thanks. I didn't even know that was there 🙂
