Seeking feedback from design or engineering professionals using Fusion 360™
dvd.mlm
dvd.mlm
Are you a design or engineering professionals using Fusion 360™ for design, validation, or manufacturing?
We want to hear how professionals like you work so that we can better meet your needs.
Share your experience in this 8-minute survey below!
Thanks for your help,
The Autodesk Research Team
Replies (9)
try your design of war equipment
lucasliraAU
answer completed successfully!
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
you should open this up to general modelers too.
TrippyLighting
@lucasliraAU and you have at least 5+ years of using CAD software in a professional (usually for-profit) environment ?
lucasliraAU
Yes, I have 5 years using CAD platforms. Developing some for-profit projects others do not!
Greetings!
See pictures below. Top one is 360. Lower 2 are Spaceclaim. Please make 360 do that with its sheet metal or we have nothing worth using. You need drop down options for Junction, Corner and Edge relief. Speed is essential in design for MFG. F360 has put really nice parametric construction into this software and relative ease of use. I really want this to be my main CAD software. How does this get addressed?
Nothing?....
TrippyLighting
Contribute to the forum 😉
Thanks. It would be nice if the sheet metal work space worked like spaceclaim. It would be a huge push on anyone on the fence of 360. Is that a difficult task?
