Let’s put aside this class-a surfacing as a term
it is kinda nonessential abstract construction
lets rather differentiate between heavy-dirty surfaces vs lightweight with perfect curvature surfaces
yhe art with quality surfacing is not g2 g3 directly but how smooth each surface patch flows into the next so when Giu then see the model without surface edges and rotate it you don’t see sudden changes in the highlights and the curvature comb shapes are good
wirh good I mean surface to surface you have min g2 transitions along all natural and trimmed edges
What fusion produces as g2 is not what Alias / ICEM would verify as g2 either
tje big question is does it matter in industrial design
a basic understanding of curvature and comb flows is essential
look here this is a nice visual explanation for surface quality and perfection
www.bluesmith.co.uk/tutorial4.htm
notice how much he shows CVs and combs
many cad models show u the patch layout and that is fine but that is only half the deal like here
what really is important is the cv layout and topology of all patches being aligned to form g2.
in Alias you can use the g2 fillet command but you still might need to had adjust cvs to get the surface check to accept g2 with certain tolerances
here this is an easy case enter patch has cvs aligned with left and right patch
but not let’s match this vertically too
y fillets are hard
check this video : https://youtu.be/KDHoBDBUfB8
Or this video
https://www.carbodydesign.com/archive/2010/06/y-fillet-class-a-surfaces-tutorial/
Compare to what fusion360 patch does
That is also why the patch tool often does show bad results - doing it real is painfully hard
Does this help a little with what class-a modeling truly is and why fusion360 class-a workshops / tutorial are kinda funny ?
a lot of rhino models or horrid
and I as a designer have no interest in being bogged down by class-a and find fusion sufficient for the concept debelopment
if needed a class-a sculptor can rebuild it
fun fact I made some sub-d models for color presents too and they did not see any issues in it
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
