See Through Rear View?
Greetings!
I'm about to move into a new Flat and in order to get the most out of it I'm planning it in CAD:
While usually not a problem with smaller Projects where you're only ever meant to view it from outside I've kinda noticed there being a bit of an issue when doing Architectural Models like the above one where if you want to look inside, the Exterior Walls will always obstruct the view.
I've kinda managed to get around this by assigning all the Exterior Surfaces a Glass Texture which will then result in ANY view from outside appearing transparent but doing that is kind of a P.I.T.A. 🤔
Soo... Is there a feature / Texture already present in F360 that would accomplish this automatically? 🤨
