So I am trying to complete a drawing for a part, and the section view is not sectioning the full part. there is a through hole on top and in the attached drawing you can see the left side has the countersink and thru hole, where the right side only displays the countersink. also there is a large pocket on the bottom that isn't showing because its showing the front of the part as evidenced by the small angled cut on the front. Perplexingly the one of the elements I care about for this section is the threaded hole on the right that is displaying both the threaded portion and the count bore and thru hole properly.
I came from SolidWorks, and this drawing package feels like MS Paint in comparison, and I am told that Inventor has a better and more comparable drawing package. If Autodesk is truly pushing Fusion as the next thing and a one stop shop, it needs to have an adequate drawing package.
