Section model while skeching
Hi all,
please see the following image:
If I want to sketch on the white plane, is there a way to see the model sectioned by that plane, so I can view my sketch and the section of the model at the exact point of the sketch?
Thanks a lot
Marco
Maybe I solved: section analysis. Right?
1. Start sketching on a face
2. Launch Section analysis and cut away the part that covers your sketch
3. Sketch
Bye
Marco
jeff_strater
Fusion will do this for you in sketch mode.  Just check the "Slice" option in the sketch panel:
which will do exactly what you want:
Jeff
Jeff Strater
Engineering Director
Good Jeff...
Only an advise: each time I draw something (like a line for example) the view unslices itself an comes back to a complete 3d view.
Thank so much
Marco
jeff_strater
Hi @Anonymous,
That does seem odd.  It's not supposed to turn off the slicing until you exit the sketch.  Can you record a screencast of what you see when you are sketching?  I'd like to see if I can spot what might be going wrong.
thanks,
Jeff
Jeff Strater
