Sculpture shell to solid object
mannbergU89AG
Observer Observer
Message 1 of 10
mannbergU89AG
Observer
Observer
I created a Form from a sketch and extruded it, rotated one of the faces and got a form / sculpture looking like the one in the attached screenshot. But the model is only a shell. How do a convert it to a solid object? I want a solid object and not a thin shell.
Replies (9)
Message 2 of 10
TheCADWhisperer
Message 3 of 10
TrippyLighting
Assuming you did this with "Capture design history" enabled or otherwise known as Timeline mode, once you click the "Finish form" button the T-Spline object is automatically converted into one or more bodies.
If this creates several bodies - open surface bodies in this case - you'll have to go into the patch environment and stitch these together to form a single open surface body. Then you can use "Create ->thicken" . That creates a separate solid body with thickness.
Message 4 of 10
mannbergU89AG
Observer
Observer
Here is the part.
Message 5 of 10
TheCADWhisperer
Is something like this what you are after?
Or this?
More information on your true design intent might help.
Message 6 of 10
TheCADWhisperer
...or this?
Message 7 of 10
mannbergU89AG
Observer
Observer
Or this?
Just like the " Solid Body.f3d" TheCADWhisperer . Thank you. How did you do that?
Message 8 of 10
TheCADWhisperer
The steps that I used are all recorded like reading a book of instructions in the Timeline.
Have you gone through the Help>Tutorials?
Message 9 of 10
Hello 🙂
I'm still a newbie.
When you say "rotated one of the faces"......how did you do that?
What happens to the timeline?
Thank you for your help. 🙂
Message 10 of 10
Hello 🙂
I'm still a newbie.
How did you put the twist in the shape and where is that on the timeline?
Thank you 🙂
