Sculpt non-selectable component
Message 1 of 8
I have created a component on 'Model' mode and I want to edit it on Sculpt mode. However, when I convert to 'Sculpt' mode, the component appears as non-selectable (transparent) or non-activated. Any ideas on how I can activate it and edit it?
Replies (7)
Message 2 of 8
TheCADWhisperer
Can you File >Export and then Attach your *.f3d file here?
Message 3 of 8
Would prefer to send this on a private message.
Message 4 of 8
TrippyLighting
You cannot just sculpt around on a solid model created in the Model environment.
What made you believe you could ?
Message 5 of 8
Okay I just thought so.
Message 6 of 8
Greetings,
  I just found this post...I had the same problem as the OP...are you saying it is impossible to go back and forth between 'Model' and 'Sculpt' environments?  I mean if project geometry is originally created in 'Model' it cannot be later 'refined' or modified in the 'Sculpt'...?  It is therefore necessary to choose one method ('Model' or 'Sculpt') at the start of a project and remain in that environment?  I also was under the impression one could move between environments for creating a 'base' model that could later be modified with more detail by sculpting refinements...that is a disappointment.
Message 7 of 8
TrippyLighting
In the model environment you are working with BRep/NURBS surfaces and in the T-Spline environment you are working with ... well ... T-Splines. Mathematically these are compatible only in one direction. T-Spline ->NURBS but not the other way around.
That means that  you can start with a T-Spline and add model features to it. Then you can go back and edit the T-Spline and the rest of the model will update.
But you cannot start with a BRep/NURBS model and convert it to a T-Spline. You can only convert parts of it (if they are quad surfaces).
Message 8 of 8
  Thank you for that helpful explanation...makes it much more understandable.  Regards.
