screw and nuts for 3d printing
thongvan.alexis
Observer Observer
thongvan.alexis
Observer
Observer
Hi;
If I model a 6mm cylinder and make a 6mm thread ont it.
Then if I do a 6mm hole in a 8mm cylinder and then make a 6mm thread in this 6mm hole.
Will it screw?
Or does the hole in the nut need to be bigger than the screw cilinder/thread?
Thanks.
TheCADWhisperer
Set threads to Modeled and compare on your screen - you should be able to see the sizes.
One problem with 3D printing threads though, is that the process is not particularly precise.
You might have to chase the threads with a tap and die.
I use a different CAD program to add a bit of extra clearance.
To answer your question - male an female threads should have the same size and pitch nomenclature, but you need to be sure to set to Modeled and not mere cosmetic representation.
The tap-drill size for a 6mm hole is not 6mm.  Fusion will resize the hole to the correct tap-drill size when you add the thread feature.
If the hole was 6mm - the fastener would simple push through the hole with no threads to engage.
All of this can be visually seen on the screen.
HughesTooling
What I normally do is model the female thread as a separate body and use a non uniform scale to increase the diameter then combine with the main body, you'll need to experiment to see what works for you. On small sizes up to about 12mm I use 1.01 as the scale factor.
Mark
Mark Hughes
Owner, Hughes Tooling
thongvan.alexis
Observer
Observer
thanks a lot, this awnser all my questions about threading 😄
