Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Screencast limitation on a laptop
3 REPLIES 3
lemelman
366 Views, 3 Replies
I needed to create a Screencast from my laptop, which has a screen resolution of 1366x768. It appeared to create OK but I have a severe problem when reviewing it - I can't access the 'play' button at the bottom 'cos it's off the bottom of the window and there is no way to either minimise or move it up a bit to make the bottom visible.
Any clues?
3 REPLIES 3
g-andresen
in reply to: lemelman
Isn´t it possible to click and drag the SC window in it´s top area.
Can you make a screenshot?
günther
LeonardoBN
Hi @lemelman. I use the same resolution as yours, and only a fraction of the buttons is visible. Here I use Windows with a narrow taskbar. It is not ideal, but I'm used with this and I memorized the positions.
I only get full access to the buttons if I auto-hide taskbar:
Leonardo Brunelli do Nascimento
Chemical Engineer
lemelman
in reply to: LeonardoBN
First off, I'm sorry for the long delay in responding, but my laptop hasn't been available for a few days, but thank you for your feedback.
Günther,  no matter what I tried, it was impossible to reduce the vertical size of the SC window.
Leonardo, eventually I was able find a setting that hid the Windows taskbar when not actually needed. With it hidden I was able to access the SC buttons OK.
I can now use SC on my laptop.
