Scotch Yoke Mechanism help
Hi Guys,
I am new to the Fusion 360. So,
Have a look to my design
http://a360.co/2kebDCO
I am trying to do the Scotch Yoke Mechanism and I don't have any idea what type of joints should I use between Chassis and the rotary Wheel.
I'm really appreciate your help or idea.
Beyondforce
Hi @Anonymous,
I hope this will help:
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Thank you @Beyondforce. It really helps me.
Beyondforce
@jeff_strater,
You will please check out my screencast, something is wrong with the joints. 2 Sliders should have worked in this scenario but they didn't!
Thanks.
Ben Korez
| YouTube
jeff_strater
Hi @Beyondforce,
A Slider joint won't work in this case because the pin actually rotates in that slot.  A slider joint requires the components to maintain the same orientation (only allows a single degree of freedom).  However, we have just the joint type for this:  A "pin slot" joint.  I thought I might need a Motion Link to make this all work together, but somewhat surprisingly (to me), it all just works!!!
Jeff
Jeff Strater
Engineering Director
