Scale Sketch between two points
Hagen_Ellermeier
Hagen_Ellermeier
Community Visitor
Community Visitor
Hey, I'm basically new to Fusion 360 and I need some help. I want to snap point 1 to point 2. If I use the Coincident constraint the sketch deforms, instead it should scale to keep its overall shape. Is there any way to achive that? If not are there any workarounds?
There are now Constraints defining the shape except that point 3 is fixed in place.
Thx in advance
Hagen
etfrench
(view in My Videos)
Is it an arc with two lines or a spline?  Why isn't it modeled on the origin?
ETFrench
davebYYPCU
Two lines and 4 splines, nothing constrained - yep will look like 2nd pic - every time.
Scale a Body much more efficient.
Might help....
Drewpan
I would strongly recommend that you do the embedded tutorials in the Fusion Documentation and also some of the
Self-Paced Learning to help you to learn fusion faster and better. They can be found here:
It is also much easier for the forum to help you if you attach your file AND a screenshot of what you want to achieve
and what the problem is. You can create a file to export like this:
It is difficult to work out exactly what you have done here without the actual file. What are you actually trying to
achieve? Is this a teardrop made of a reflected spline or a semicircle and a couple of lines? The construction  method
makes a difference. When drawing and modeling, symetry is always your friend and cuts down workload considerably.
Using the Origin and axes is also very important and will help a great deal with symetry. Drawing something at a
random point in space makes your job harder.
If what you want is a scaleable extrusion of a teardrop then it will always be better to sketch half the teardrop on the
Origin using your preferred method. Mirror the half using the axes. Extrude the shape and THEN scale it. It is better
workflow and gives much more robust results. This may not make a difference with a trivial tear drop but makes a huge
difference with a complex design that you may tackle down the track.
Here is the way I created a teardrop shape and scaled it using both methods.
Cheers
Andrew
