Saving / recovery error message
KirillChepizhko
KirillChepizhko
I get this message a lot, randomly. Does anyone know why ?507658779714b3e9083495dcb6ab445b.png
jeff_strater
Yes, this one is admittedly a bit confusing.
Fusion saves a "crash recovery" file every once in a while, in case Fusion crashes, we can recover the file.  However, this process cannot run while a command is active.  So, if you have  a command that you have been running for a long time, the crash recovery process never gets a chance to do the save.  This dialog is just telling you that you are a bit "unprotected" because this has not happened.  You can either save (by clicking "Save") at this point, or ignore it by clicking "Cancel".
Hope this clears up the mystery.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
