Saved work is blank.
All my Fusion 360 designs aren't showing up on the left side of the screen like they usually do. Although the computer knows it's there because it shows the recovered file. Are you guys having problems with synchronization on your end?
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm sorry you are experiencing this issue.
Are you unable to see the data panel or save the file?
If your data panel is grey out, could you follow this thread? https://forums.autodesk.com/t5/fusion-360-support/data-panel-is-completely-empty-after-updating-12-07-17/m-p/7610910#M16069
If not, could you explain what the issue is in detail?
I look forward to your reply
Many thanks,
Ahreum.
It was just a random glitch it's fine now.
