Save body as STL and save component as STL give different file sizes
Posed this question to Autodesk tech support and got some theories, but no definitive answer. Opening it up to the community. Here's the issue:
You have a component with only one active body. Selecting "Save as STL" for the component results in a different STL than if you select "Save as STL" for the active body. The file size is different, and if you check the number of faces of the resulting STL, it's also different. Why? I would think these two files should be identical.
I've noticed instances with greater than 2x the resulting file size when saving from the component vs. saving from the body.
This raises a few questions:
1. Why are they different?
2. Is the bigger file "better"? Or does it contain extraneous information?
3. If the goal is high-resolution 3D-printing, which saving method is the recommended one?
Thanks!
You can see the difference below. The component and the body were both saved as STL. Then they were re-imported back into Fusion. The part from the saved component is on the left, and the part from the saved body is on the right. The fidelity is clearly different, even though the exact same settings were used in the "Save as STL" dialog box.
