Save as DXf
Save as DXf
andrew.todd1
Save as DXf
andrew.todd1
Hi guys
see attached. I have 35 sketches. can i merge these into one and save the whole thing as a DXF?
Tearing my hair out here.
Project attached.
HughesTooling
Never tried but have you tried downloading from the online dashboard?  Just navigate to the design and select download and select DXF as the file type, might not export the sketch but worth a try.
Another option window select the curves with all sketches visible, hide all sketches, create a new sketch and paste.
Mark
Mark Hughes
Owner, Hughes Tooling
etfrench
These appear to be identical parts.  You only need to model one, then use a pattern to place them.  Use one pattern for the horizontal ones and one for the vertical.  Use the Suppress option to remove unneeded parts.
To create a dxf from the current file, I extruded a rectangular block, then extruded each sketch to cut the block. A sketch was created on the face of the block, then the block was projected to the sketch.  Finally, the sketch was exported as a dxf.
ETFrench
andrew.todd1
Thanks for all the help man. Sorted 🙂
andrew.todd1
Thanks for your help man. The online option worked
Mark
however the DXF it exported was out of scale. very limited support for this on Fusion i feel.
