@jiang_peng
I understand your point and the logic makes sense but it shows that users are confused by how the UI displays data.
So we add smooth constraint. First Fusion does not allow you in anyway adjust the G1 and G2 point position or weight like with cv curves.
I think that is what most non solid modeler users will look for. Alias blend curve is also pretty smooth
In Fusion often the smooth constraint is only step one because they to adjust accelerationa and such you need to add the dimensions.
And with a G2 constraint you can on Fusion only access to the G1 value via the tangent handle.
The problem is that you see the position of the handle and see the shape of the spline so you would assume that with the dimension
added and not changing the tangent handle the spline will remain the shape.
After all the fit curves auto adjust the handles so one can assume that the handle always represents some value to massage the curve.
I hope this makes sense why @Anonymous feels confused when he adds the value.
I cannot wait till the sketch engine has cv curves and aling commands for g0 g1 and g2 like in Alias because I find the spline tool very hard/labor intensive
to use and often it adds needles complexity to a design process.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
