Question on rounding edges. While doing this on a couple inside corners it work rather easily to create a circle in my project and then draw out straight lines from my edges to the bottom of the project and cut out what I didn't need. Each of the intersecting lines created a point of which I could select the segments I didn't need.
However when using a similar technique and creating a circle in a corner where I wanted to form the outer rounded end for some reason where the lines intersect it will not let me cut just that portion of the line. At one point I found that my circle I added wasn't on the same level as the main material. I attempted to match that up but it still wouldn't work.
I will attach my project here. If anyone could steer me in the right direction on how to do this would be greatly appreciated.
