Rounded Face
Rounded Face
jordankis
Rounded Face
jordankis
Is there a way to make a rounded face similar to this feature in Aspire. I am able to almost do it by tracing it with a spline and using the Rule Fillet but still having problems. The S used in my example was from exploding the text in Fusion.
Jordan
laughingcreek
sweep or loft would do it.  attached is an example with sweep.
jordankis
That wouldn't work for all object shapes, like this for example.
TrippyLighting
No it would not. But you did not ask that in your initial post.
jordankis
I kind of did....I asked how to make a rounded surface but the example I used could somewhat be created using a circle swept along a path.
What I would like to do is be able to take any arbitrary surface shape and extrude it with rounded edges similar to having a large fillet that completely rounds a surface.
wmhazzard
Use the form workspace.
Lynn_Kim
This is Screencast for you.
Try it!
I attatched f3d file
린킴 Lynn Kim (Fusion 360, Dynamo)
