rotational joints on parts with rotation joints
chrisZG6MF
Observer Observer
chrisZG6MF
Observer
Observer
so i am working on a part with a rotation joint that also has another part with another rotation joint. both parts at times can move together which is fine but also i want the to rotate separately as well with out affecting the other? in fusion im not able to do this. i can in solidworks. is there maybe another way to do the joints to where this will work. its pretty annoying and hard to show movement with the way it is working
jhackney1972
It may be possible to right click on the joint your do not want to move and select "Lock" from the context menu.
John Hackney, Retired
lauri_barnhart
Hello, @chrisZG6MF,
Did the information provided by @jhackney1972 help you and answer your question?
If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Lauri | Community Manager
