Rotating Fan Component in Fusion 360 to then Place in Flow Design wind tunnel
Is it possible to have a rotating fan component in Fusion 360 to then place in Flow Design wind tunnel to Coandă effect?
tyler_henderson
You can create a rotating fan assembly in Fusion, however; you will need to export it as a format that will work with Flow Design, and once in Flow Design, the fan will not rotate.  It will behave as one solid part.  So you may be able to simulate the Coanda effect but only as if the fan blades were static wings.
Tyler Henderson
Principal User Experience Designer
Thanks Tyler,
As you said, I was able to get a solid model without rotating fans into Flow Design, which helped with the general aerodynamics but doesn't prove out the conflict of directional air flow combined with fan flow. To do this it looks like I will will have to use Autodesk CFD which will allow both rotating fan airflow and directional air flow.
I appreciate your feedback.
Alastair.
tyler_henderson
Hi Alastair,
Yes, Autodesk CFD would be your best bet for this type of analysis.
Tyler Henderson
