Rotating a Component
Probably a silly question but--
How do you rotate a component?  I have done move, set the pivot point grabbed the triad, but the triad moves without the component.
Allan Steinkuhl
Oceanconcepts
Make sure you have the Components option selected in the Move Dialog. I find it easiest to select the component in the browser, by using the right mouse button to select the move tool.
If the Triad is rotating by itself, I wonder if you have managed to activate the Set Pivot option, used to reposition the manipulator, but not accepted the new position. Clicking the check mark will lock the pivot.
- Ron
Mostly Mac- currently M1 MacBook Pro
It appears there are two components.  One is copied from the other.
They are linked together.
I broke the link and it started rotating.
Allan Steinkuhl
