Rotate Sketch Plane, Sketch Plane Origin
Hi there: I have a sketch on an origin plane. I just want to rotate it by 30 deg.
I tried to redefine sketch plane - you need a pre-constructed plane to select. OK, I'll make a construction plane. ... Uh oh, it does not allow you to select the construction plane in the redefine command. GRRRR.....
After searching on this as much as possible, the best I found was to select everything in the original sketch, then copy and past into a NEW sketch on the construction plane. WEll, OK...
... So I do this, and the origin of the new sketch is basically RANDOM with respect to the origin of the design. so, it's very difficult to move the mess of copied-and-pasted stuff onto the right place on the sketch. Yuk.
1) Is there some way of just rotating a sketch around an axis, or redefining a sketch plane to a construction plane?
2) If not, is there some way to make the origin of a sketch on a construction plane coincident with the origin of the design?
Thanks mucho,
-TPC
