Rollcage design
Rollcage design
Message 1 of 9
Rollcage design
Hello Designers,
Myself Mahfoole, a rookie in the fusion 360 app.
Can anyone help me with a tutorial of ATV tubular rollcage design.
Replies (8)
Message 2 of 9
dan.banach
Hi mahfoole.sslc
Have you looked at the Pipe command? Here are links to a couple YouTube tutorials:
Hope this helps.  -Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 9
Aaron.Magnin
Another option is to use sweeps and sketches (3d is best, but if you're new, start with 2d)
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-B9F61274-36F9-424E-9E99-36A270C15067
Welcome to Fusion 360!
Aaron Magnin
Technical Marketing Manager Fusion 360
Message 4 of 9
keqingsong
This thread should be helpful too: https://forums.autodesk.com/t5/design-validate-document/frame-roll-cage-sprue-modeling/td-p/6644365
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 5 of 9
dwoodville
Do you have any idea if using the sweep command will allow for the model to be exported and bent on a CNC bender?
Message 6 of 9
TrippyLighting
@dwoodville You need to find out what data and in what format your CNC bender requires. If the manufacturer has a document online that explains this, maybe you can provide a link to it.
Message 7 of 9
dieselguy65
as great as fusion is.
and i use it alot
there is dedicated software for roll cage design.
and it can output for cnc benders
i use bendtech3d
been using it since its release some 25 yrs ago ro so. i was on the first few people to try it out before the official release
Message 8 of 9
dwoodville
Hey @dieselguy65 thanks for the suggestion. I have bendtech but wasn't able to use it for very long due to complications of using windows on my mac. So for now I'm trying to make fusion360 work and really want to design some things. I've tried searching for videos but I always seem to come up short and never get all the info I'm looking for.
Message 9 of 9
dwoodville
Thank you @TrippyLighting
