Ripples in Shelled Form
This is my first time posting on this board, although I have found a lot of helpful information here for other issues! Thank you to the Fusion360 pros out there!
So I have an issue with a form that I have shelled, where ripples have appeared in the shelled form. I have shelled this part (a bicycle saddle) to 1mm thickness, and in a certain region these ripples have appeared:
Screen Shot 2017-12-28 at 8.52.34 AM.pngScreen Shot 2017-12-28 at 8.53.12 AM.png
I did not get an error during shelling. Note that the right region is ripple free. Also I am using the Mac version of Fusion360. I would greatly appreciate any help here as to what might be causing this and how I can resolve it! Thanks!!
jeff_strater
Hi @Anonymous,
Welcome to the Fusion forum.  Can you post your design here, so we can take a look at it?  How was this created?  Is this a Sculpt body, or was this created with a solid loft, patch, or something else?
Jeff
Jeff Strater
Engineering Director
I created this using the sculpt environment, so it is a sculpt body.
jeff_strater
Thanks for the model, @Anonymous,
I was able to get pretty good results using a couple of TSpline techniques.  First: Use Box Mode.  This shows you the underlying scaffolding that is used for the TSpline body.  If you see lots of jagged edges in box mode, that's usually a sign of "tension" in your model.  So, the first thing is to smooth those out using Edit Form.  Second, I think this body has too many TSpline edges in it.  I got good results deleting some of those edges.  In general, you should use as few as possible to get the shape you are after.
Here is a video (no sound - the rest of the family is still sleeping today...):
Hope this helps.  Here are the results I was able to get:
Screen Shot 2017-12-28 at 8.15.20 AM.pngScreen Shot 2017-12-28 at 8.15.10 AM.png
Model is attached
Jeff Strater
Awesome, thank you @jeff_strater! This was my first time using the sculpt environment, I definitely learned some lessons from this, thanks again!
