Rigid groups not selecting all parts in assembly
jay_lu84VXY
jay_lu84VXY
Hi, I've recently encountered a problem with rigid grouping that I have not seen before.
Previously, I have modified self-centering vice models for machining use in fusion. They have joints and rigid bodies so that the jaws slide along the model, so that when jointing it to stock it should be representative of real life. However, when modelling in a manufacturing model recently, I have noticed that the rigid groups only select the one of the components in the group, and it will not drag the rest of the model with it when moving/jointing. As far as i'm aware, this has only started occuring in the past few months
Please see attached model, it works fine as a standalone, but when inserted with derive, the rigid groups do not function properly.
Many thanks,
Jay
jay_lu84VXY
So having tested further, it seems to be a bug with "insert derive". Pulling the part into an assembly with "insert component" maintains all the rigids correctly. This means it is not possible to get correctly jointed workholding models within a manufacturing model as it does not allow "insert component" commands
