Without seeing the actual model file, what you have explained seems to make perfect sense.
The children are being created by the parametric input and grouped at the same time. The only children that fusion
knows about are the ones you just created. How does fusion know if you create more children in the future to link
them to this rigid group? If you want to add more components to a group it is a new item on the timeline. If you wind
the timeline back, change the parameters then a new set of children will be created based on those parameters and
will be grouped because that is the only thing fusion "knows" about. Any more components you add to this group
should be added by the new timeline entry when you wind the timeline back to the end.
The children are created by the parameter. If you change the parameter without moving the timeline back then it
"should" create more children but there should also be a new entry in the timeline, fusion will not automagically wind
back the timeline, fix the group and wind the timeline back - you do that.
The timeline is exactly that - a time line. If you create something in the past then it cannot forsee the future, even if
the future exists because the timeline is not designed that way. Where the timeline is is what fusion knows and
calculates. Move the timeline forward and it re-calculatess because it now knows more. All of the stuff in the future is
what fusion stores and uses to re-calculate as the timeline advances. This is why it is sometimes critical to fix yellow
and red items in the timeline as they happen because they can break the model so badly later with bad data.
It seems to be doing what is on the box. I know this right now and I can calculate it. If you change the parameter
I will step through the timeline and re-calculate everything then add this new bit you have just changed but I am
adding (or subtracting) it when you tell me to. If the change is not compatible with what I know I will throw a red or
yellow warning.
Cheers
Andrew
