revolve
revolve
不适用
577 次查看
8 条回复
1 条消息(共 9 条)
revolve
不适用
cant get the "revolve function ro work, what am i doing wrong ,
Sculpt, Create , Revolve .  , but then nothing ?
Help please
thanks
Malcolm
0 个赞
578 次查看
8 条回复
回复 (8)
2 条消息(共 9 条)
PhilProcarioJr
Can you post a screen shot of what your trying to revolve?
Phil Procario Jr.
Owner, Laser & CNC Creations
0 个赞
3 条消息(共 9 条)
不适用
try that
0 个赞
4 条消息(共 9 条)
jeff_strater
Revolve requires an axis to revolve around.  So, add a line to your sketch to represent the axis of revolution.  The command has an input for selecting the axis:
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
5 条消息(共 9 条)
PhilProcarioJr
Jeff beat me to it.....lol
Phil Procario Jr.
0 个赞
6 条消息(共 9 条)
不适用
Ok, got that bit guys , thanks , but the issue that i have is the "revolve" dialoque box does not come up !!
0 个赞
7 条消息(共 9 条)
不适用
Ok, bit more trial and error got there in the end .
Thanks Guys !!!
0 个赞
8 条消息(共 9 条)
不适用
Here is the solution of your problem. that how to use revolve command.
Solution:
www.youtube.com/watch?v=qH0kdlqhK5U
If this solve your issue, please accept this as a solution
0 个赞
9 条消息(共 9 条)
TrippyLighting
Solution:
This is the Fusion 360 Forum. Your screencasts are about AutoCAD , an entirely different application that also has it's own Forum.
0 个赞
