Revolute joints for tetrahedral spaceframe
Hi all,
I'm working on generating build instructions for a spaceframe made of equal-length members bent at 70 and 110 degrees:
As you can see, as-built assembly involves a sort overlap weave of the tabs, which have a small amount of flexibility inherent to steel sheets required to properly assemble:
As you might predict, when I try to set up this exact assembly with 3x 70-bent members (to form the vertex of a tetrahedron), the joints don't quite align:
So, I'm fudging the assembly a bit by mating the parts to overlap each other, which seems to have done the trick as far as hole alignment goes - however, my problem is that when I set all the joints to revolve, the assembly inverts itself:
 Any ideas on how to get this assembly done properly?
70 degree member attached for reference.
Charlie
I've managed to get the first vertex set up but now I can't get any of the edges to line up. This seems to be the challenging part:
Here's the essence of the problem:
Why is this happening?
I realized that this problem is occurring because the dihedral angle is not exactly 70 degrees, it is calculated by arccos(1/3) which is approx 70.5288.
